查看: 92632|回复: 962
[原创教程] 普通机后处理改为进玉自动出程序单后处理
发表于 2011-7-24 20:30:47 | 显示全部楼层 |阅读模式
普通机后处理改为进玉自动出程序单后处理视频
tcl文件如下修改
一、加output_desr
proc MOM_end_of_program { } {
   MOM_force Once M_coolant
   MOM_do_template coolant_off
   MOM_force Once M_spindle
   MOM_do_template spindle_off
   PB_CMD_program_end1
   MOM_do_template end_of_program
   MOM_set_seq_off
   MOM_do_template rewind_stop_code
   PB_CMD_program_end2
output_desr
#**** The following procedure lists the tool list with time in commentary data
   LIST_FILE_TRAILER
#**** The following procedure closes the warning and listing files
   CLOSE_files
二、加prog_head
proc PB_start_of_program { } {
   if [llength [info commands PB_CMD_kin_start_of_program] ] {
prog_head
   PB_CMD_init_turbo
   MOM_set_seq_off
   PB_CMD_program_start
   PB_CMD_init_helix
   PB_CMD_fix_RAPID_SET
三、加spindle_check,set_value_ju
proc MOM_start_of_path { } {
  global mom_sys_in_operation
   set mom_sys_in_operation 1
  global first_linear_move ; set first_linear_move 0
   TOOL_SET MOM_start_of_path
   if [llength [info commands PB_CMD_kin_start_of_path] ] {
   PB_CMD_start_of_operation_force_addresses
   PB_CMD_path_start
spindle_check
set_value_ju
四、加cut_depth_circular
proc MOM_linear_move { } {
  global feed_mode mom_feed_rate mom_kin_rapid_feed_rate
   if { ![string compare $feed_mode "IPM"] || ![string compare $feed_mode "MMPM"] } {
      if { [EQ_is_ge $mom_feed_rate $mom_kin_rapid_feed_rate] } {
         MOM_rapid_move
         return
   global mom_sys_abort_next_event
   if { [info exists mom_sys_abort_next_event] } {
      if { [llength [info commands PB_CMD_kin_abort_event]] } {
五、加cut_depth_line
   if { !$first_linear_move } {
      PB_first_linear_move
      incr first_linear_move
   MOM_do_template linear_move
cut_depth_line}
六、加在最后面
proc MOM_end_of_group { } {
   prog_end
proc prog_head { } {
   global mom_group_name mom_date mom_tool_name
   global prev_spind
   global  tool_name  cut_descr  cut_stock  cut_depth
   set tool_name ""
   set cut_descr ""
   set cut_stock 1
   set cut_depth 0
   set prev_spind 0
#   MOM_output_literal "%"
#   MOM_output_literal "( ttp )"
#   MOM_output_literal "(PROGRAM NAME: $mom_group_name)"
#   MOM_output_literal "(Time: $mom_date)"
#   MOM_output_literal "(Cutter Name: $mom_tool_name)"
#   MOM_output_literal "T1D1"
#   MOM_output_literal "HSCB(0.01)"
#   MOM_output_literal "G90G54G00X0.Y0."
proc prog_end { } {
#   MOM_output_literal "G91 Z150."
#   MOM_output_literal "M05"
#   MOM_output_literal "M09"
#   MOM_output_literal "M30"
proc spindle_check { } {
   global mom_spindle_speed prev_spind
   if { $mom_spindle_speed  < 1  } {
      if { $prev_spind == 0 } {
          set mom_spindle_speed  1500
         } else {
                set mom_spindle_speed  $prev_spind
   set prev_spind $mom_spindle_speed
proc set_value_ju { } {
   global mom_tool_name   mom_stock_part
   if { $tool_name == "" } {
      set tool_name $mom_tool_name
      } else {
             if { $tool_name != $mom_tool_name } {
                                                  set tool_name "操作中刀径不同"
    if { $cut_stock == 1 } {
       set cut_stock $mom_stock_part
       } else {
               if { $cut_stock > $mom_stock_part } {
   if { $cut_stock < 0 } {
            set cut_descr "光"
      } elseif { $cut_stock >= 0 && $cut_stock <= 0.1 } {
                set cut_descr "中"
      } else {
                set cut_descr "粗"
proc cut_depth_line { } {
   global cut_depth
   global mom_pos
   if { $cut_depth > $mom_pos(2) } {
      set cut_depth $mom_pos(2)
proc cut_depth_circular { } {
   global cut_depth
   global mom_pos
proc output_desr { } {
   global  mom_group_name  mom_machine_time
   global mom_output_file_basename  mom_output_file_directory  mom_sys_output_file_suffix
   set desr_file_name "${mom_output_file_directory}${mom_output_file_basename}.${mom_sys_output_file_suffix}"
   MOM_close_output_file $desr_file_name
   set desr_file_name "D:\\ju_conf\\temp\\$mom_group_name.xl"
   MOM_remove_file $desr_file_name
   MOM_open_output_file $desr_file_name
   MOM_output_literal "$mom_group_name  $tool_name  $cut_descr  [format %3.2f $cut_stock]  [format %4.1f $cut_depth] [format %4.0f $mom_machine_time]"
发表于 2013-9-11 18:41:59 | 显示全部楼层
dbank:ZGJhbms6Ly9kb3dubG9hZC9saW5rP25hbWU9XFVH57uP6aqM5oqA5ben5aSn5YWoLnJhciYmdXJsPWh0dHA6Ly9kbC52bWFsbC5jb20vZG93bmxvYWQvVUclRTclQkIlOEYlRTklQUElOEMlRTYlOEElODAlRTUlQjclQTclRTUlQTQlQTclRTUlODUlQTgucmFyP2Y9YzBwYWJhOGx3OCZpPSZoPTEzNzg4OTQ4MzEmdj1hZGNiMDE4MyZ1PTFlZmQxMjI5JmlwPTU4LjI1NC40LjY4JnA9MzAmbHBpZD0mdGM9MSZhdWlkPSZscz0mJmlzZGlyPTA=
发表于 2014-11-28 13:32:56 | 显示全部楼层
希望楼主管理员   给个编辑好的(比如自动换刀_通用_ys,)     我ys基础改了还是出现以上问题     在说改的一至五项加到什位置啊?  强烈支持!!!
发表于 2014-9-15 01:11:09 | 显示全部楼层
非常感谢,非常感谢,非常感谢,非常感谢,非常感谢,非常感谢,非常感谢,非常感谢,非常感谢,非常感谢,非常感谢,非常感谢,非常感谢,非常感谢,非常感谢,非常感谢,非常感谢,非常感谢,
今天又来了
 楼主| 发表于 2011-7-24 20:41:48 | 显示全部楼层
修改成功的后处理,能自动出单,带turbo指令,后处理速度非常快
postprocessor.rar (202.01 KB, 下载次数: 4126)
发表于 2011-9-26 15:06:09 | 显示全部楼层
还是没弄清楚怎么修改?
发表于 2011-10-28 12:34:31 | 显示全部楼层
学习学习下!多谢了,下来慢慢研究
发表于 2011-10-28 21:21:08 | 显示全部楼层
加加加,加在哪里嘛,是不是加在cut_depth_circular后面,
说都没有说清楚,
发表于 2011-10-28 21:45:35 | 显示全部楼层
骗 人的,加了也不行,强烈要求斑主出视屏教程,
点评
有修改好的对照,请仔细对照!  发表于 2011-11-13 15:13
参与人数 1Q币 +4 收起 理由
kushao + 4 www.qqkan.cc/riben-tv/yiwendingqing2013/
发表于 2011-10-28 22:41:58 | 显示全部楼层
不行呀,没成功,强烈要求斑主出视屏教程!
发表于 2011-11-6 15:20:06 | 显示全部楼层
老大,能不能搞个视频出来晒晒啊!!!!
发表于 2011-11-6 15:20:57 | 显示全部楼层
老大,能不能搞个视频出来晒晒啊!!!!
发表于 2011-11-7 23:02:15 | 显示全部楼层
袁老师真的很佩服你 接下来再帮我看看这个问题怎么解决 我用的是win764位系统 32位的UG7.5 后处理是进玉公司修改好的后出理在UG4.0里面平行铣走的很好但在7.5里面做的程式后处理后在同一台机上跑的好慢进给快都不行,,急 急 急! 望袁老师能帮解决。我是高阳春。
