帖子
查看: 2305|回复: 1
[英语综合] 常用实验仪器英文名称
发表于 2012-5-29 17:42:12 | 显示全部楼层 |阅读模式
玻璃漏斗 Glass funnel long stem
试管   test tube test tube brush test tube holder test tube rack
蒸发皿   evaporating dish small三维
烧杯 beaker
锥形瓶 Erlenmeyerwww
量筒 grad cylinder
洗瓶 plastic wash bottle
勺皿 casserole ,small
分液漏斗 separalory funnel
water bath/oil bath
strring bar
magnetic stirrer
冷凝器 condenser
Ballast bottle
圆颈烧瓶 Round-buttom flask
试剂瓶 reagent bottles
托盘天平 platform balance 台秤
0.1g 托盘pan 指针刻度表pointer and scale
crossbeams and sliding weights 游码
分析天平 two-pan/single-pan analytical balance
滴定管 burette glass bead(basic) nozzle
移液管 pipette 胖肚 elongated glass bulb
洗耳球 rubber suction bulb
玻棒 glass rod
玻璃活塞 stopcock
容量瓶 pyknowmeter flasks
比重瓶 (one-mark)volumetric flasks
胖肚吸管 one-mark pipette
刻度吸管 graduated pipettes
Class “A” higher grade
Class ”B” lower grade
Ml millilitre
Ex—the pipette has been adjusted to deliver its indicated capacity
Ex+15s waiting time
实验仪器清单
1、 柜子中 四、抽屉中:
锥形瓶(conical flask) 250ml×4 药匙(medicine spoon)×1
(Erlenmeyer flask) 100 ml×3 滴管(drip tube;dropper)×2
烧杯(beaker) 500 ml×1 玻棒(Glass stic)×2
250 ml×3 木试管夹(test tube clamp;test tube holder)×1
100 ml×3 胖肚吸管(straws) 25 ml×1
50 ml×2 10 ml×1
容量瓶(volumetric flask) 100 ml×2 乳钵(morta)×1
50 ml×4 洗耳球(ear wadhing bulb)
碘量瓶 (iodin numoe flask;iodineflask) 500 ml×3
试剂瓶 (reagent bottle) (无色)×2
棕色)×2 配洗液:
量筒(cylinder) 100 ml×1 K2Cr2O72g+5ml水→65mlH2SO4
(graduated cylinder)10ml×1 边加边搅拌(stir)。
二、台面上仪器: 一般仪器的洗涤(wash)
铁支架(siderocradle)+蝴蝶架
白瓷板(White Porcelain Board ) (一)清点仪器(to count;to make an inventory)
酸式滴定管(Acid burette) 25 ml×1 配洗液 (Lotion)
碱式滴定管(Alkali burette)25 ml×1 一般仪器的洗涤
三、公用柜中: (二)滴定管(buret;burette)
直型冷凝器(rectocondensor)×1 容量瓶(volumetric flask)
漏斗架 (funnel stand) ×2 移液管(pipe)
水浴锅(water bath kettle) ×1
温度计(Thermometer;hygrometer;hydroscope) ×1
电炉(electric furnace;electric hot plate;electric stove) 四人一个
循环水式真空水泵:WATER-JET ASPIRATOR PUMP
旋转蒸发仪:ROTARY VACUUM EVAPORATOR
恒温磁力搅拌器:Constant temperature magnetic stirrer
电热恒温鼓风干燥箱:Electro-Thermostatic Blast Oven
集热式恒温加热磁力搅拌器:Heat collection-Constant temperature type magnetic stirrer
微信小程序
微信订阅号
请微信扫码咨询
