查看: 29434|回复: 224
[Dynaform] Dynaform后处理用户手册
发表于 2012-7-22 16:40:20 | 显示全部楼层 |阅读模式
目录
目 录............................................................................................................I
前 言.........................................................................................................IV
第一章 系统结构概述................................................................................1
1.1 概述....................................................................................................................1
1.2 菜单栏................................................................................................................2
1.3 图标栏................................................................................................................3
1.4 显示选项..........................................................................................................11
1.5 功能的优先级..................................................................................................12
1.6 控制窗口及控制选项窗口..............................................................................13
1.7 文件格式..........................................................................................................13
1.8 配置文件..........................................................................................................13
第二章 开始使用.........................................................................................16
2.1 从D3PLOT 文件开始使用.............................................................................16
2.2 软硬件系统需求..............................................................................................17
第三章 文件管理.........................................................................................18
3.1 打开文件..........................................................................................................18
3.2 导入文件..........................................................................................................19
3.3 导出文件..........................................................................................................20
3.4 拷贝到剪贴板..................................................................................................20
3.5 打印..................................................................................................................21
3.6 退出..................................................................................................................23
第四章 编辑菜单.........................................................................................24
4.1 创建线..........................................................................................................24
4.2 删除线..........................................................................................................26
4.3 标记/箭头.....................................................................................................26
4.4 旋转光源......................................................................................................27
4.5 光源特性......................................................................................................27
4.6 颜色表..........................................................................................................30
4.7 零件属性......................................................................................................31
4.8 用户自定义视角..........................................................................................38
4.9 背景颜色......................................................................................................39
第五章 工具箱...........................................................................................41
5.1 截面剖切..........................................................................................................42
5.2 运动约束..........................................................................................................51
5.3 沿XYZ轴镜像结果.........................................................................................52
5.4 定义活动窗口..................................................................................................54
5.5 定义节点轨迹..................................................................................................55
5.6 零件等值线结果历史曲线..............................................................................56
5.7 节点等值线结果历史曲线..............................................................................58
5.8 单元等值线结果历史曲线..............................................................................58
5.9 模型摘要..........................................................................................................59
第六章 选项...............................................................................................61
6.1 在图形区显示坐标轴的开关........................................................................61
6.2 在图形区显示标题的开关............................................................................61
6.3 在图形区显示图标的开关............................................................................61
6.4 在图形区显示图标的开关............................................................................62
6.5 模型法向颜色显示开关................................................................................62
6.6 显示单元方向的开关....................................................................................63
6.7 活性云图范围................................................................................................63
6.8 定义绕转中心................................................................................................64
第七章 后处理.........................................................................................65
7.1 变形................................................................................................................66
7.2 等值线............................................................................................................70
7.3 矢量................................................................................................................76
7.4 成形极限图....................................................................................................79
7.5 厚度................................................................................................................83
7.6 最大和最小主应变........................................................................................86
7.7 面内应变........................................................................................................87
7.8 坯料与工具间的距离....................................................................................89
7.9 圆栅格............................................................................................................91
7.10 滑移标记........................................................................................................93
7.11 坯料轮廓........................................................................................................95
7.12 材料流动........................................................................................................97
7.13 缺陷检查........................................................................................................99
第八章 曲线图.............................................................................................68
8.1 开始操作..........................................................................................................68
8.2 载入曲线表数据文件......................................................................................69
8.3 曲线表控制窗口..............................................................................................80
8.4 曲线操作..........................................................................................................82
附录 A 硬件和软件要求............................................................................99
后 记.........................................................................................................101
Dynaform后处理用户手册
链接:http://pan.baidu.com/s/1nuE6XKX
  1. u9lh
发表于 2019-8-7 19:58:09 | 显示全部楼层
赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞赞
发表于 2018-8-10 08:46:40 | 显示全部楼层
ai爱她不敢说
发表于 2015-12-11 18:16:17 | 显示全部楼层
学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习学习
ai爱她不敢说
发表于 2012-7-23 08:22:17 | 显示全部楼层
学习一下
发表于 2012-7-24 00:00:22 | 显示全部楼层
不错的资料
发表于 2012-8-7 07:59:52 | 显示全部楼层
真是好资料,非常感谢!
发表于 2012-8-7 09:28:32 | 显示全部楼层
好资料,谢谢
发表于 2012-8-7 16:25:52 | 显示全部楼层
dFDFDAFDFDFADFADF
发表于 2012-8-28 20:28:27 | 显示全部楼层
好资料,有源文件吗
发表于 2012-9-11 22:26:53 | 显示全部楼层
貌似很丰富呀
发表于 2012-9-11 22:27:27 | 显示全部楼层
4.5M,大家都知道了哈
发表于 2012-9-13 17:07:11 | 显示全部楼层
好东西好东西好东西好东西好东西好东西
