楼主: liuting
[网盘资源] UG后处理(支持进玉自动程序单批处理)
发表于 2013-9-25 00:53:01 | 显示全部楼层
{:soso_e163:}
顶顶顶顶
发表于 2013-9-26 14:40:50 | 显示全部楼层
RTREERGFDG
发表于 2013-9-27 22:44:24 | 显示全部楼层
看一下是不是好东西
发表于 2013-10-7 19:05:07 | 显示全部楼层
顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶
发表于 2013-10-8 17:19:37 | 显示全部楼层
8888888888888
发表于 2013-10-9 22:32:01 | 显示全部楼层
tcl文件如下修改
一、加output_desr
proc MOM_end_of_program { } {
    MOM_force Once M_coolant
    MOM_do_template coolant_off
    MOM_force Once M_spindle
    MOM_do_template spindle_off
    PB_CMD_program_end1
    MOM_do_template end_of_program
    MOM_set_seq_off
    MOM_do_template rewind_stop_code
    PB_CMD_program_end2
output_desr
#**** The following procedure lists the tool list with time in commentary data
    LIST_FILE_TRAILER
#**** The following procedure closes the warning and listing files
    CLOSE_files
二、加prog_head
proc PB_start_of_program { } {
   if [llength [info commands PB_CMD_kin_start_of_program] ] {
prog_head
   PB_CMD_init_turbo
    MOM_set_seq_off
    PB_CMD_program_start
    PB_CMD_init_helix
    PB_CMD_fix_RAPID_SET
三、加spindle_check,set_value_ju
proc MOM_start_of_path { } {
   global mom_sys_in_operation
    set mom_sys_in_operation 1
  global first_linear_move ; set first_linear_move 0
    TOOL_SET MOM_start_of_path
   if [llength [info commands PB_CMD_kin_start_of_path] ] {
   PB_CMD_start_of_operation_force_addresses
    PB_CMD_path_start
spindle_check
set_value_ju
四、加cut_depth_circular
proc MOM_linear_move { } {
   global feed_mode mom_feed_rate mom_kin_rapid_feed_rate
   if { ![string compare $feed_mode "IPM"] || ![string compare $feed_mode "MMPM"] } {
       if { [EQ_is_ge $mom_feed_rate $mom_kin_rapid_feed_rate] } {
          MOM_rapid_move
          return
   global mom_sys_abort_next_event
    if { [info exists mom_sys_abort_next_event] } {
       if { [llength [info commands PB_CMD_kin_abort_event]] } {
五、加cut_depth_line
   if { !$first_linear_move } {
       PB_first_linear_move
       incr first_linear_move
   MOM_do_template linear_move
cut_depth_line}
六、加在最后面
proc MOM_end_of_group { } {
    prog_end
proc prog_head { } {
    global mom_group_name mom_date mom_tool_name
    global prev_spind
   global  tool_name  cut_descr  cut_stock  cut_depth
   set tool_name ""
    set cut_descr ""
    set cut_stock 1
    set cut_depth 0
   set prev_spind 0
#   MOM_output_literal "%"
#   MOM_output_literal "( ttp )"
#   MOM_output_literal "(PROGRAM NAME: $mom_group_name)"
#   MOM_output_literal "(Time: $mom_date)"
#   MOM_output_literal "(Cutter Name: $mom_tool_name)"
#   MOM_output_literal "T1D1"
#   MOM_output_literal "HSCB(0.01)"
#   MOM_output_literal "G90G54G00X0.Y0."
proc prog_end { } {
#   MOM_output_literal "G91 Z150."
#   MOM_output_literal "M05"
#   MOM_output_literal "M09"
#   MOM_output_literal "M30"
proc spindle_check { } {
    global mom_spindle_speed prev_spind
   if { $mom_spindle_speed  < 1  } {
       if { $prev_spind == 0 } {
           set mom_spindle_speed  1500
          } else {
                 set mom_spindle_speed  $prev_spind
   set prev_spind $mom_spindle_speed
proc set_value_ju { } {
    global mom_tool_name   mom_stock_part
    if { $tool_name == "" } {
       set tool_name $mom_tool_name
       } else {
              if { $tool_name != $mom_tool_name } {
                                                   set tool_name "操作中刀径不同"
    if { $cut_stock == 1 } {
       set cut_stock $mom_stock_part
        } else {
                if { $cut_stock > $mom_stock_part } {
   if { $cut_stock < 0 } {
             set cut_descr "光"
      } elseif { $cut_stock >= 0 && $cut_stock <= 0.1 } {
                 set cut_descr "中"
      } else {
                 set cut_descr "粗"
proc cut_depth_line { } {
    global cut_depth
    global mom_pos
   if { $cut_depth > $mom_pos(2) } {
      set cut_depth $mom_pos(2)
proc cut_depth_circular { } {
    global cut_depth
    global mom_pos
proc output_desr { } {
    global  mom_group_name  mom_machine_time
    global mom_output_file_basename  mom_output_file_directory  mom_sys_output_file_suffix
   set desr_file_name "${mom_output_file_directory}${mom_output_file_basename}.${mom_sys_output_file_suffix}"
    MOM_close_output_file $desr_file_name
    set desr_file_name "D:\\ju_conf\\temp\\$mom_group_name.xl"
    MOM_remove_file $desr_file_name
    MOM_open_output_file $desr_file_name
    MOM_output_literal "$mom_group_name  $tool_name  $cut_descr  [format %3.2f $cut_stock]  [format %4.1f $cut_depth] [format %4.0f $mom_machine_time]"
发表于 2013-10-15 15:36:32 | 显示全部楼层
非常感谢楼主
发表于 2013-10-15 19:53:47 | 显示全部楼层
{:soso_e183:}
