查看: 25076|回复: 142
[ANSYS] Ansys Workbench中添加APDL扩展workbench功能
发表于 2012-11-28 15:17:35 | 显示全部楼层 |阅读模式
链接:http://pan.baidu.com/s/1eSHdtlC
  1. 6m5v
参与人数 1Q币 +8 收起 理由
发表于 2014-2-24 16:33:24 | 显示全部楼层
楼主,请教如何在Workbench中实现ENORM command的功能,APDL的命令格式是什么呢,或是在tree下可以直接操作?
仿真时出现的ERROR:
*** ERROR ***                           CP =       8.533   TIME= 20:42:22
The normal of target element 108946 is not consistent with the normal
of target element 110088.  Please use the ENORM command to correct it.
请问您,这个问题该如何解决,非常感激!
发表于 2019-1-24 11:24:19 | 显示全部楼层
有限元分析遇到错误The normal of target element 62628 is not consistent with the normal of
target element 64531 in real set 35.  Please use the ENORM command to
correct it.
有点伤心 ...
发表于 2018-11-9 01:59:31 | 显示全部楼层
ádasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdádasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasdasd
【温馨提示】技术问题 ...
发表于 2012-12-10 19:08:13 | 显示全部楼层
dingdingding
发表于 2012-12-31 10:59:02 | 显示全部楼层
henhaoahenaho
发表于 2013-6-19 23:50:21 | 显示全部楼层
感谢楼主分享,十分需要
发表于 2013-6-23 15:06:28 | 显示全部楼层
楼主。。。ANSY可以进行冲压模拟吗?
发表于 2013-7-7 15:52:43 | 显示全部楼层
看了LZ的帖子,我只想说一句很好很强大!
发表于 2013-8-2 13:04:15 | 显示全部楼层
哥顶的不是帖子,是寂寞!
发表于 2013-12-11 09:54:16 | 显示全部楼层
太感谢楼主了,顶一个!!
