查看: 68791|回复: 885
[分享资料] Cimatron四轴后处理大全
发表于 2013-2-23 11:48:34 | 显示全部楼层 |阅读模式
Cimatron四轴后处理大全
链接:http://pan.baidu.com/s/1qX7ggTe
  1. hb4m
参与人数 1Q币 +240 收起 理由
优胜模具 + 240 每次回帖系统奖励1 Q币,回帖越多,发帖收益越高。
发表于 2019-3-27 13:30:17 | 显示全部楼层
LINEAR MOTION: FAST:
      FlagSpin = NO ;
      IF_SET (SPIN_SPEED) FlagSpin = YES ; END_IF ;
      IF_SET (SPIN_DIR)   FlagSpin = YES ; END_IF ;
      IF_SET (FlagSpin _EQ_ YES)
         SET_ON SPIN_SPEED SPIN_DIR ;
         OUTPUT $ " S" SPIN_SPEED " " SPIN_DIR ;
      END_IF ;
      OUTPUT $ ;
      IF_SET (LIN_MOV)  OUTPUT " " LIN_MOV   ; END_IF ;
      IF_SET (X_CURPOS) OUTPUT " X" X_CURPOS ; END_IF ;
      IF_SET (Y_CURPOS) OUTPUT " Y" Y_CURPOS ; END_IF ;
      IF_SET (Z_CURPOS) OUTPUT " Z" Z_CURPOS ; END_IF ;
      IF_SET (MCH_COOL) OUTPUT  " " MCH_COOL ; END_IF ;
      SET_ON CIRC_MOV NURBS_MOV ;
      Xold = X_CURPOS ;
      Yold = Y_CURPOS ;
      Zold = Z_CURPOS ;
LINEAR MOTION:
      FlagSpin = NO ;
      END_IF ;
      OUTPUT $ ;
      IF_SET (CUTCOM_ON)  OUTPUT " "  CUTCOM_ON " D" CutterComp ; END_IF ;
      IF_SET (CUTCOM_OFF) OUTPUT " "  CUTCOM_OFF ; END_IF ;
      IF_SET (MCH_FEED)   OUTPUT " F" MCH_FEED   ; END_IF ;
      SET_ON CIRC_MOV NURBS_MOV;
      Xold = X_CURPOS ;
      Yold = Y_CURPOS ;
      Zold = Z_CURPOS ;
CIRCULAR MOTION:
      FlagSpin = NO ;
      END_IF ;
      DXcenter = X_CENTER - Xold ;
      DYcenter = Y_CENTER - Yold ;
      DZcenter = Z_CENTER - Zold ;
      OUTPUT $ ;
      IF_SET (CIRC_MOV)          OUTPUT " " CIRC_MOV  ; END_IF ;
      IF_SET (X_CURPOS)          OUTPUT " X" X_ENDPT  ; END_IF ;
      IF_SET (Y_CURPOS)          OUTPUT " Y" Y_ENDPT  ; END_IF ;
      IF_SET (Z_CURPOS)          OUTPUT " Z" Z_ENDPT  ; END_IF ;
      IF_SET (DXcenter _NE_ 0.0) OUTPUT " I" DXcenter ; END_IF ;
      IF_SET (DYcenter _NE_ 0.0) OUTPUT " J" DYcenter ; END_IF ;
      IF_SET (DZcenter _NE_ 0.0) OUTPUT " K" DZcenter ; END_IF ;
      SET_ON LIN_MOV NURBS_MOV ;
      Xold = X_CURPOS ;
      Yold = Y_CURPOS ;
      Zold = Z_CURPOS ;
NURBS MOTION: START:
OUTPUT $ NURBS_MOV "P" NURBS_DEG ;
count = 0;
first = 1;
SET_ON MCH_FEED;
NURBS MOTION:
IF_SET (first _EQ_ 1)
OUTPUT "K" KNOT_ "X" CNTRL_X "Y" CNTRL_Y "Z" CNTRL_Z "F" MCH_FEED;
END_IF;
IF_SET (first _EQ_ 0)
OUTPUT $ "K" KNOT_ "X" CNTRL_X "Y" CNTRL_Y "Z" CNTRL_Z;
END_IF;
first = 0;
NURBS MOTION: END:
deg = NURBS_DEG ;
REPEAT
count = count + 1 ;
OUTPUT $ "K" KNOT_ ;
UNTIL (count _EQ_ deg) ;
SET_ON LIN_MOV CIRC_MOV MCH_FEED;
INSERT WITH:
      OUTPUT $ INS_STR ;
INSERT WITHOUT:
      OUTPUT  \J INS_STR ;
MESSAGE:
      OUTPUT $ "( " MESS_STR " )"  ;
CYCLE: ON:
      FlagSpin = NO ;
      END_IF ;
      SET_ON X_CURPOS Y_CURPOS Z_CURPOS   ;
      SET_ON CYC_DEPTH CYC_RETR CYC_CLEAR MCH_FEED MCH_COOL ;
      SET_ON Zinit Depth Clear ;
      Zinit    = Z_CURPOS + CYC_DZINIT ;
      Depth    = Z_CURPOS - CYC_DEPTH ;
      Clear    = Z_CURPOS + CYC_CLEAR ;
      IF_SET (Zold _LT_ Zinit)
                        OUTPUT $ " Z" Zinit ;
          ELSE
                        OUTPUT $ " Z" Zold ;
          END_IF ;
                         OUTPUT $ ;
                         OUTPUT " "  CYC_RETR ;
                         OUTPUT " "  CYC_CODE ;
                         OUTPUT " Z" Depth    ;
                         OUTPUT " R" Clear ;
      IF_SET (CYC_PECK)  OUTPUT " Q" CYC_PECK  ; END_IF ;
      IF_SET (CYC_DWELL) OUTPUT " P" CYC_DWELL ; END_IF ;
      IF_SET (CYC_XSHFT) OUTPUT " I" CYC_XSHFT ; END_IF ;
      IF_SET (CYC_YSHFT) OUTPUT " J" CYC_YSHFT ; END_IF ;
      SET_ON  LIN_MOV CIRC_MOV ;
      SET_OFF CYC_DEPTH CYC_CLEAR;
      Xold = X_CURPOS ;
      Yold = Y_CURPOS ;
      Zold = Z_CURPOS ;
CYCLE:
      OUTPUT $ ;
      IF_SET (CYC_RETR)   OUTPUT " "  CYC_RETR   ; END_IF ;
      IF_SET (Depth)      OUTPUT " Z" Depth      ; END_IF ;
      IF_SET (Clear)      OUTPUT " R" Clear      ; END_IF ;
      IF_SET (SPIN_SPEED) OUTPUT " S" SPIN_SPEED ; END_IF ;
      IF_SET (SPIN_DIR)   OUTPUT " "  SPIN_DIR   ; END_IF ;
      Xold = X_CURPOS ;
      Yold = Y_CURPOS ;
      Zold = Z_CURPOS ;
CYCLE: OFF:
      OUTPUT $ " G80 Z" Zinit ;
      Zold = Zinit ;
ORIGIN CHANGE:
*-----Save the first origin data for later use
   IF_SET (FirstOriginChange _EQ_ YES )
         XfirstOrigin      = X_ORIGIN  ;
         YfirstOrigin      = Y_ORIGIN  ;
         ZfirstOrigin      = Z_ORIGIN  ;
         FirstOriginChange = NO        ;
   END_IF ;
*.....distance between the rotation center and the ORIGIN
      TRANS_MATX = X_ORIGIN - XfirstOrigin - X_MACH  ;
      TRANS_MATY = Y_ORIGIN - YfirstOrigin - Y_MACH  ;
      TRANS_MATZ = Z_ORIGIN - ZfirstOrigin - Z_MACH  ;
*      SET_OFF CIR_INTERP ;    (去除 * 号则不输出G02、G03)
*.....check for change in orientation ( 4,5 axis positioining )
    FlagError  = NO ;
    Flagrotmac = no ;
   IF_SET ( I_ORIGIN _NE_ ORIGOLDI ) FLAGROTMAC = YES ; END_IF ;
   IF_SET ( J_ORIGIN _NE_ ORIGOLDJ ) FLAGROTMAC = YES ; END_IF ;
   IF_SET ( K_ORIGIN _NE_ ORIGOLDK ) FLAGROTMAC = YES ; END_IF ;
   IF_SET ( FLAGROTMAC _EQ_ YES )     FlagError  = YES ; END_IF ;
   IF_SET (FlagError _EQ_ YES)
       PRINT  \J "Error: ucs rotation was found in:" ;
       PRINT  \J "       TP=" TP_NAME " PROC=" PROC_NUM " (" PROC_NAME ")" ;
       PRINT  \J "Error: Cannot post ucs rotaion toolpaths" ;
       OUTPUT \J " M00 (Error: ucs rotation was found)" ;
       OUTPUT \J " M00 (TP=" TP_NAME " PROC=" PROC_NUM " - " PROC_NAME ")" ;
   END_IF ;
   ORIGOLDI = I_ORIGIN ;
   ORIGOLDJ = J_ORIGIN ;
   ORIGOLDK = K_ORIGIN ;
AXISCHANGE:
    FlagError  = NO ;
    IF_SET (AXIS_NUM  _GT_ 3)         FlagError = YES ; END_IF ;
       PRINT  \J "Error: 4/5 axes motion was found in:" ;
       PRINT  \J "Error: Cannot post 5 axes toolpaths" ;
       OUTPUT \J " M00 (Error: 4/5 axes motion was found)" ;
    END_IF ;
SUBROUTINE CALL:
      CurrSubNum = SUB_NUMBER + StartSubNum ;
      OUTPUT $ " M98 P" CurrSubNum  ;
BEGINNING OF SUB:
      SET_ON  MCH_FEED MCH_COOL LIN_MOV CIRC_MOV ;
      FlagSub = YES ;
      OUTPUT \J " " ;
      IF_SET (FlagSeq _EQ_ YES)
         OUTPUT \J "O" CurrSubNum ;
      ELSE
         OUTPUT \J " O" CurrSubNum ;
      END_IF ;
END OF SUB:
      OUTPUT $  " M99" ;
      FlagSub = NO ;
SUBROUTINE RETURN:
      SET_ON LIN_MOV CIRC_MOV X_CURPOS Y_CURPOS Z_CURPOS;
0.0.。。
发表于 2013-12-31 16:48:29 | 显示全部楼层
UG 论坛
ProE论坛
SolidWK
Caxa论坛
设计论坛
数控论坛
优胜专栏
UG 外挂
模具培训
快速发帖
PM 论坛
Catia论坛
CimatrE
MastCAM
五金论坛
机械论坛
鞋模论坛
PM 外挂
发布招聘
发帖求助
帖子
热搜: NX8.0胡波进玉优胜杨成洛克凌超杨师傅郭冲展陈老师龚老师史老师
模具资料网›论坛›Cimatron论坛›CimatronE 外桂&后处理›Cimatron四轴后处理大全› 参与/回复主题
RE: Cimatron四轴后处理大全 [修改]
Undo
Redo全屏常用
纯文本
字体大小 Hr
B I U Color BgColor Url Unlink
Table
Removeformat
AutotypesetLeftCenterRight
该会员没有填写今日想 ...
发表于 2018-8-15 18:23:41 | 显示全部楼层
控论坛
优胜专栏
UG 外挂
模具培训
快速发帖
PM 论坛
Catia论坛
CimatrE
MastCAM
五金论坛
机械论坛
鞋模论坛
PM 外挂
发布招聘
发帖求助
帖子
Undo
Redo全屏常用
纯文本
字体大小 Hr
Table
Removeformat
按时来到福 ...
发表于 2013-2-23 13:43:39 | 显示全部楼层
好啊
谢谢
发表于 2013-2-23 14:27:53 | 显示全部楼层
Cimatron的四轴后处理比较少。
又来下东西了
发表于 2013-2-23 14:28:59 | 显示全部楼层
看看是什么机床
发表于 2013-2-23 15:41:57 | 显示全部楼层
发表于 2013-2-23 18:36:58 | 显示全部楼层
aaaaaaaaaaaaaaaaaaaaa
发表于 2013-2-25 13:10:29 | 显示全部楼层
Cimatron的四轴好东西
发表于 2013-2-27 20:57:11 | 显示全部楼层
看看是什么机床
发表于 2013-3-2 19:25:19 | 显示全部楼层
cimatron_4轴后处理下来玩玩。
javascript:void(0);
发表于 2013-3-3 12:36:03 | 显示全部楼层
急求   谢谢
