查看: 3212|回复: 2
[讨论求助] 请问后处理里面,SWA是什么意思
发表于 2013-5-15 07:00:42 | 显示全部楼层 |阅读模式
以下是我的旋转雕的后处理程序,A轴旋转轴没有精确到小数点后四位,雕出来的东西很毛,有哪信高手帮我修改下,X轴是精确到小数点后四位的
machine fanuc15m
#310
  message output         = false
  block order            = true
  incremental centre     = true
  tool reset coordinates = 3
  counter start          = 1
  counter increment      = 1
  integer 69             = 2
  zero                   = "0.0"
#319
  spindle azimuth rotation   = false
  azimuth axis units         = degrees
  azimuth axis direction     = positive
  azimuth centre             = ( 0.0 0.0 0.0 )
  azimuth axis param         = ( 0.0 0.0 0.0  0.0 0.0 0.0 )
  spindle elevation rotation = false
  elevation axis units       = degrees
  elevation axis direction   = positive
  elevation centre           = ( 0.0 0.0 0.0 )
  elevation axis param       = ( 0.0 0.0 0.0  1.0 0.0 0.0 )
  pcs origin                 = ( 0.0 0.0 0.0  0.0 0.0 0.0 )
  linear axis limits         = ( -9999.0 9999.0 -9999.0 9999.0 -9999.0 9999.0 )
  rotary axis limits         = (  -0.0  0.0  -20000.0 20000.0  0.05 0.03 )
  initial tool vector            = ( 0 0 1 )
  workplane angles               = none
  retract at angular limit       = false
  unwind at tool change          = false
  multiaxis coordinate transform = true
  linearise multiaxis moves      = false
  withdrawal amount              = 100.0
  integer 3                      = 1
#344
  define block tape start
    %D Day ; %M Month ; %Y Year ; %h Hour ; %m Minutes ; %s Seconds ; " )"
    if ( DPversion < 1361 )
      error " MINIMUM DUCTPOST VERSION REQUIRED = 1361"
    end if
    VER DPversion ; OFN OptionFileName ; " )"
    ID JobName
    N ; G4 05 =C ; " P10000"
    N ; G2 40 ; G3 17 ; G4 80 ; G6 49
    N ; G5 91 ; G6 28 ; z coord 0
  end define
#357
  define block tool change first
    TT ToolType ; " )"
    TN ToolName ; " )"
    if ( ToolType = "BALLNOSED" or ToolType = "ENDMILL" or ToolType = "DRILL" )
      TD ToolRadius ; TLH ToolLength ; " )"
    else
      TD ToolRadius ; TR TipRadius ; TLH ToolLength ; " )"
    end if
    THK Thickness ; " )"
    NT ToolNum ; T ToolNum ; change tool
    N ; G5 90 ;
    set swa
  end define
#371
    if ( cycledwell = 0 )
      N ; G4 80 ; M2 9 ; M3 59
    end if
    if ( cycledwell > 0 )
      N ; G4 05 =C ; " P0"
    end if
    N ; G5 91 ; G6 28 ; z coord 0 =C
    N ; G6 49 ; H  0
    N ; G6 28 ; x coord  0 =C ; y coord 0 =C
    TT ToolType ; " )"
    TN ToolName ; " )"
    else
    end if
    N ; G5 90 ;
    set swa
  end define
#394
  define block move from
  end define
#397
  define block cldat 1094
    set swa
  end define
#401
  define block move rapid
    if ( swa )
      TPN ToolPathName ; " )"
      "( ToolPath Time" ;
      tpt    ToolPathTime ;
      secs ( Word{tpt} % 60 ) ;
      mins ( Word{tpt} - Word{secs} / 60 % 60 ) ;
      hrs  ( Word{tpt} / 60 - Word{mins} / 60  ) ; act ( Word{act} + Word{tpt} ) ;
      %h Word{hrs} ; %m Word{mins} ; %s Word{secs} ; " )"
      if ( Word{act} > Word{tpt} )
        "( Accumulative Time " ;
        secs ( Word{act} % 60 ) ;
        mins ( Word{act} - Word{secs} / 60 % 60 ) ;
        hrs  ( Word{act} / 60 - Word{mins} / 60 ) ;
      end if
     unset swa
    end if
    N ; G1 ; G2 ; G4 ; G5 ; G6 ; x coord ; y coord ; z coord ;
        elevation axis ; tool length ; spindle ; M1 ; M2
  end define
#427
  define block move linear
    if ( swa )
      "( ToolPath Time" ;
      tpt    ToolPathTime ;
      end if
     unset swa
    end if
    N ; G1 ; G2 ; x coord ; y coord ; z coord ;
        elevation axis ; tool length ; spindle ; feedrate ; M1 ; M2
  end define
#453
  define block move circle
    N ; G1 ; G2 ; G3 ; x coord ; y coord ; z coord ; radius =C ; feedrate
  end define
#457
  define block cycle start
    if ( cycle = 2 or cycle = 3 or cycle = 5 )
      # DRILL
      N ; G4 ; G5 ; G6 ; drill hole depth ; clearplane ; drill peck depth ;
          DW cycledwell ; feedrate
    end if
    if ( cycle = 6 )
      # Bore
      N ; G4 ; G5 ; G6 ; drill hole depth ; clearplane ; Q1 300 =C ; feedrate
    end if
    if ( cycle = 1 and cycledwell > 0 )
      # G82 DRILL AND DWELL
      N ; G4 ; G5 ; G6 ; drill hole depth ; clearplane ; DW cycledwell ; feedrate
    end if
    if ( cycle = 1 and cycledwell = 0)
      # G82 DRILL
      N ; G4 ; G5 ; G6 ; drill hole depth ; clearplane ; feedrate
    end if
    if ( cycle = 4 )
      # TAP
      N ; M1 29 ; S ToolSpeed =C ; M2 3 =C
    end if
  end define
#482
  define block move cycle
    N ; x coord ; y coord ; z coord ; feedrate
  end define
#486
  define block move tap
  end define
#490
  define block cycle end
    end if
    end if
  end define
#499
  define block tape end
    N ; G5 91 ; G6 28 ; x coord 0 =C
    N ; G6 28 ; y coord 0 =C
    N ; M1 30
  end define
end
 楼主| 发表于 2013-5-15 07:02:40 | 显示全部楼层
只是问一下,红色字体的SWA是什么意思??
发表于 2014-9-26 09:35:46 | 显示全部楼层
dddddddddddddd
