帖子
查看: 28566|回复: 230
[分享资料] MasterCAM X7下载 中文纯净版 最新!
发表于 2013-5-28 13:27:23 | 显示全部楼层 |阅读模式
版本运行环境: Windows 7 32位 或64位  和Windows 8 64位
【温馨提示】 如果您要查看本帖隐藏内容请回复
32位主程序下载:
32位破解 (含破解说明): http://pan.baidu.com/share/link?shareid=542513&uk=1258687182
X7 汉化32位:http://pan.baidu.com/share/link?shareid=542516&uk=1258687182
64位主程序下载:
64位破解 (含破解说明):http://pan.baidu.com/share/link?shareid=539074&uk=1258687182
参与人数 2Q币 +124 收起 理由
优胜网络服务 + 100 奖励 Q币
优胜模具 + 24 每次回帖系统奖励1 Q币,回帖越多,发帖收益越高。
发表于 2014-1-13 13:31:47 | 显示全部楼层
ATTENTION!
If you already have USB-Emulator for MC X4-X5 (HASP or NetHASP)  installed you can skip steps 1) - 5) and need only to run "mastercam_X5_crk.exe"
1) Unpack a folders "USB-Emul_Win64" and  "remove_old_emuls"  to your computer
2) Run "remove_old_emuls\delete_old_emuls.bat"  to CLEAR a Windows Registry from "blacklisted" Emulators
3) Run "mcamX4_MU3-dealer-nethasp.reg" or "mcamX4_MU3-industrial-nethasp.reg" (dealer dump has got extended functionality!) if you want to install Mastercam X5 with NetHASP SIM type.
        or
run "mcamX4_MU3-dealer_hasp.reg" if you want to install Mastercam X5 with HASP SIM type.
4) Install a USB-Win64 Emulator
You need a local Administrator rights to install this emulator for Win64!
On Windows Vista64 and Windows7 64-bit you need to boot Windows in mode F8 > Desable Unsigned Drivers Enforcment !!!
4.1. Reboot computer (for Windows Vista64 and Windows7 64-bit you need to boot Windows in mode F8 > Desable Unsigned Drivers Enforcment !!!)
4.2.   Install usb-emulator drivers
  Start ->  Control Panel -> Add Hardware (Yes, I have already connected the hardware) -> Add a new hardware device -> Install the hardware that I manually select from a list -> Show all Devices -> Have disk -> Browse -> (browse to folder "USB-Emul_Win64") -> OK -> Confirm to install not certificated drivers if Windows ask for..
If setup is succesfull you have to see new system device:
Device Manager -> System devices -> Virtual Usb Bus Enumerator
5)  Install MC X5 as HASP or NetHASP SIM type.
6) Copy Mastercam.exe from crack to <Mastercam X6 progdir> and replace original one
7) Enjoy
该休息了
发表于 2017-7-5 16:00:00 | 显示全部楼层
撒旦法阿斯蒂芬撒旦法诗圣杜甫阿斯蒂芬阿萨德发送到发生大幅撒        钱钱钱钱钱钱钱钱钱钱钱钱钱钱钱钱呜呜呜呜呜呜呜呜呜呜呜呜呜呜呜呜呜呜呜呜呜噩噩噩噩噩噩噩噩噩噩噩噩噩噩噩噩噩噩噩噩日日日日日日日日日日日日日日日日日日日日日日
发表于 2014-10-2 23:30:41 | 显示全部楼层
RE: MasterCAM X7下载 中文纯净版 最新! [修改]
白目白目白 ...
发表于 2013-5-28 14:09:20 | 显示全部楼层
沙发........
发表于 2013-5-28 14:10:07 | 显示全部楼层
弱弱的问一声64位的汉化呢?
发表于 2013-5-28 15:32:02 | 显示全部楼层
没见到64汉化文件哦
好好学习
发表于 2013-5-28 17:11:12 | 显示全部楼层
mastercamx7-x64 安装完了64位,破解也正常完成,电脑也重新启动按了F8"禁用驱动程序签名强制"的,打开软件时无法运行,打开报警“无法定位程序输入点?is_chook@@YADPEBD@Z于动态链接库Mastercam.exe上。
发表于 2013-5-30 09:08:05 | 显示全部楼层
汉化呢怎么没有看到?
111555看看
发表于 2013-6-16 11:23:48 | 显示全部楼层
不错,又占了一个沙发!
发表于 2013-7-10 18:58:54 | 显示全部楼层
有没有繁体版
发表于 2013-7-21 09:21:37 | 显示全部楼层
谢谢楼主了,顶一下
发表于 2013-8-8 11:22:21 | 显示全部楼层
64位汉化呢怎么没有看到?
微信小程序
微信订阅号
请微信扫码咨询
