楼主: YMY2011
[分享资料] MasterCAM法兰克车床后处理
发表于 2018-12-27 09:11:46 | 显示全部楼层
赞赞赞赞 赞 赞赞 赞 赞在2在2赞 赞 赞 赞 赞 赞 赞
【温馨提示 ...
发表于 2018-12-28 21:52:31 | 显示全部楼层
好东西,多谢
发表于 2019-1-3 12:55:43 | 显示全部楼层
好好学习天天向上
解决
发表于 2019-1-4 09:48:11 | 显示全部楼层
XIEXIE qunzhu 牛逼
【温馨提示 ...
发表于 2019-1-8 13:21:23 | 显示全部楼层
RE: MasterCAM法兰克车床后处理 [修改]
发表于 2019-1-28 16:21:28 | 显示全部楼层
感谢楼主的辛苦分享
很好的
发表于 2019-2-19 19:15:56 | 显示全部楼层
spaces      : 1     #Number of spaces to add between fields
omitseq     : YES    #Omit sequence numbers?
seqmax      : 9999  #Max. sequence number
arcoutput   : 1     #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
arctype     : 2     #Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.
breakarcs   : 2     #Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs
do_full_arc : 0     #Allow full circle output? 0=no, 1=yes
helix_arc   : 2     #Support helix arc output, 0=no, 1=all planes, 2=XY plane only
compwarn    : 1     #Warn if cutter comp applied on arc, 0=no, 1=yes
maxrad      : 999   #Maximum arc radius
hel_2100    : no    #Acramatic 2100 style helical moves, 0=no, 1=yes
usecanned   : yes   #Use canned drilling cycles?  Set to no for long output.
force_dpts  : no    #Force XY output on all drilling lines including cycle call?
wcstype     : 2     #0 = G92 at start, 1 = G92 at toolchanges, 2 = G54, 3 = Off
force_wcs   : yes   #Force WCS output at every toolchange?
stagetool   : 1     #0 = Do not pre-stage tools, 1 = Stage tools
tool_table  : 1     #Tool table, 0=no, 1=yes, 2=Predator VCNC, 3=MetaCut View
output_z    : yes   #Output Z Min and Z Max values (yes or no)
cool_zmove  : no   #Coolant off with last move
use_pitch   : 0     #0 = Use feed for tapping, 1 = Use pitch for tapping
tap_feed    : 0     #0 = 2/1 (in/mm) decimal places, 1 = 4/3 (in/mm) decimal places
maxfeedpm   : 500   #Limit for feed in inch/min
maxfeedpm_m : 10000 #Limit for feed in mm/min
use_gear    : 0     #Output gear selection code, 0=no, 1=yes
max_speed   : 20000 #Maximum spindle speed
min_speed   : 50    #Minimum spindle speed
sextnc      .NC     #NC extension override
# Rotary Axis Settings
# Typical Vertical
srotary     "A"     #Rotary axis prefix
vmc         : 1     #0 = Horizontal Machine, 1 = Vertical Mill
rot_on_x    : 1     #Default Rotary Axis Orientation, See ques. 164.
                     #0 = Off, 1 = About X, 2 = About Y, 3 = About Z
# Typical Horizontal
#srotary     "B"     #Rotary axis prefix
#vmc         : 0     #0 = Horizontal Machine, 1 = Vertical Mill
#rot_on_x    : 2     #Default Rotary Axis Orientation, See ques. 164.
#                    #0 = Off, 1 = About X, 2 = About Y, 3 = About Z
rot_ccw_pos : 1     #Axis signed dir, 0 = CW positive, 1 = CCW positive
ret_on_indx : 1     #Machine home retract on rotary index moves, (0 = no, 1 = yes)
index       : 0     #Use index positioning, 0 = Full Rotary, 1 = Index only
ctable      : 5     #Degrees for each index step with indexing spindle
one_rev     : 0     #Limit rotary indexing between 0 and 360? (0 = No, 1 = Yes)
lock_codes  : 1    #Use rotary axis unlock/lock M-Codes? (0 = No, 1 = Yes)
use_frinv   : 0     #Use Inverse Time Feedrates in 4 Axis, (0 = no, 1 = yes)
rot_feed    : 1     #Use calculated rotary feed values, (0 = no, 1 = yes)
maxfrdeg    : 2000  #Limit for feed in deg/min
maxfrinv    : 999.99#Limit for feed inverse time
frc_cinit   : 1     #Force C axis reset at toolchange
ctol        : 225   #Tolerance in deg. before rev flag changes
ixtol       : .01   #Tolerance in deg. for index error
frdegstp    : 10    #Step limit for rotary feed in deg/min
【温馨提示 ...
