帖子
查看: 3033|回复: 2
[原创教程] X6默认后处理整圆或IJK输出时,不输出I0,J0,K0 方法
发表于 2013-12-2 15:14:09 | 显示全部楼层 |阅读模式
搜索"parc ", 注是parc加个空格,搜索到以下块,看红色部分提示就明白了,把IJKOUT前面的*号去掉就不用输出I0J0K0了。
parc            #Select the arc output
      if (plane$ = zero & (arctype$ = one | arctype$ = four)) |   #XY Plane
        (plane$ = one & (arctypeyz$ = one | arctypeyz$ = four)) | #YZ Plane
        (plane$ = two & (arctypexz$ = one | arctypexz$ = four)),  #XZ Plane
        result = newfs(two, iout)
        result = newfs(two, jout)
        result = newfs(two, kout)
      else,
        result = newfs(three, iout)
        result = newfs(three, jout)
        result = newfs(three, kout)
      if (plane$ = 0 & arctype$ < five) | (plane$ = 1 & arctypeyz$ < five) |
        (plane$ = 2 & arctypexz$ < five) | full_arc_flg$ | arc_pitch$,
        #Arc output for IJK
        # If you do NOT want to force out the I,J,K values,
        # remove the "*" asterisks on the *i, *j, *k 's below...
        if plane$ = zero, *iout, *jout, kout #XY plane code - G17
        if plane$ = one, iout, *jout, *kout  #YZ plane code - G19
        if plane$ = two, *iout, jout, *kout  #XZ plane code - G18
        !i$, !j$, !k$
      else,
        #Arc output for R
        if abs(sweep$)<=180 | (plane$ = 0 & arctype$ = five) | (plane$ = 1 & arctypeyz$ = five) |
          (plane$ = 2 & arctypexz$ = five), result = nwadrs(srad, arcrad$)
        else, result = nwadrs(srminus, arcrad$)
        *arcrad$
修改后
        #Arc output for IJK
        if plane$ = zero, iout, jout, kout #XY plane code - G17
        if plane$ = one, iout, jout, kout  #YZ plane code - G19
        if plane$ = two, iout, jout, kout  #XZ plane code - G18
        !i$, !j$, !k$
好久没有来了
发表于 2013-12-2 18:35:23 | 显示全部楼层
好好好好好好好
节日快乐无比
发表于 2015-11-2 11:19:46 | 显示全部楼层
谢谢分享   学习一下
温馨提示:优胜教师团 ...
微信小程序
微信订阅号
请微信扫码咨询
