查看: 1656|回复: 1
[转载文章] 教你跟老外用英语做模具检讨
发表于 2013-12-26 14:44:44 | 显示全部楼层 |阅读模式
1. 产品里面的这个位置我们打算做斜顶或内行位,有问题吗?
We will make the lifter and (inner) slider in this position, will that be a problem?
2. 你提供的2D产品图与3D产品图不一致,请问以哪一个图面为准?
The 2D and 3D drawing you provided is not the same, can you tell me which one is correct?
3. 你提供的3D产品图有的地方没有出模角,有的地方胶位太厚,有的地方胶位太溥,这些产品问题我们可以自己修改吗?修改后会给交给你确认。
There is no draft angle in the 3D drawing, some materials are too thick, and some place are too thin. Can we modify this part by ourselves? We will send the drawing to you for you to check after we modify it.
教你跟老外用英语做模具检讨(933.17K)
发表于 2014-4-28 12:29:27 | 显示全部楼层
good!good!good!good!good!good!good!good!
