查看: 14698|回复: 109
[数控] PM精加工刀路案例
发表于 2015-4-23 19:29:10 | 显示全部楼层 |阅读模式
链接:http://pan.baidu.com/s/1gds31q7
  1. dkp5
发表于 2018-10-13 01:36:12 来自手机 | 显示全部楼层
https://d.pcs.baidu.com/file/a44e2b5e83fb404db1e9454d80bad904?fid=3355929204-250528-997484276351080&time=1500609503&rt=sh&sign=FDTAERVY-DCb740ccc5511e5e8fedcff06b081203-e9LrdqoUhbYn1N3pjWEGmMIfITM%3D&expires=8h&chkv=1&chkbd=0&chkpc=et&dp-logid=4673327927671607625&dp-callid=0&r=204371128https://d.pcs.baidu.com/file/a44e2b5e83fb404db1e9454d80bad904?fid=3355929204-250528-997484276351080&time=1500609503&rt=sh&sign=FDTAERVY-DCb740ccc5511e5e8fedcff06b081203-e9LrdqoUhbYn1N3pjWEGmMIfITM%3D&expires=8h&chkv=1&chkbd=0&chkpc=et&dp-logid=4673327927671607625&dp-callid=0&r=204371128https://d.pcs.baidu.com/file/a44e2b5e83fb404db1e9454d80bad904?fid=3355929204-250528-997484276351080&time=1500609503&rt=sh&sign=FDTAERVY-DCb740ccc5511e5e8fedcff06b081203-e9LrdqoUhbYn1N3pjWEGmMIfITM%3D&expires=8h&chkv=1&chkbd=0&chkpc=et&dp-logid=4673327927671607625&dp-ghcallid=0&r=204371128yy
发表于 2017-7-21 12:00:03 | 显示全部楼层
https://d.pcs.baidu.com/file/a44e2b5e83fb404db1e9454d80bad904?fid=3355929204-250528-997484276351080&time=1500609503&rt=sh&sign=FDTAERVY-DCb740ccc5511e5e8fedcff06b081203-e9LrdqoUhbYn1N3pjWEGmMIfITM%3D&expires=8h&chkv=1&chkbd=0&chkpc=et&dp-logid=4673327927671607625&dp-callid=0&r=204371128https://d.pcs.baidu.com/file/a44e2b5e83fb404db1e9454d80bad904?fid=3355929204-250528-997484276351080&time=1500609503&rt=sh&sign=FDTAERVY-DCb740ccc5511e5e8fedcff06b081203-e9LrdqoUhbYn1N3pjWEGmMIfITM%3D&expires=8h&chkv=1&chkbd=0&chkpc=et&dp-logid=4673327927671607625&dp-callid=0&r=204371128https://d.pcs.baidu.com/file/a44e2b5e83fb404db1e9454d80bad904?fid=3355929204-250528-997484276351080&time=1500609503&rt=sh&sign=FDTAERVY-DCb740ccc5511e5e8fedcff06b081203-e9LrdqoUhbYn1N3pjWEGmMIfITM%3D&expires=8h&chkv=1&chkbd=0&chkpc=et&dp-logid=4673327927671607625&dp-callid=0&r=204371128
发表于 2021-12-13 21:21:32 | 显示全部楼层
查看: 6373|回复: 108
打印 上一主题 下一主题 [数控] PM精加工刀路案例   [复制链接]
aixiaoyu1413
avatar
104
主题
40
0
中级会员
收听TA 发消息
电梯直达
跳转到指定楼层 1#
在线会员 发表于 2015-4-23 19:29:10 | 只看该作者 |只看大图 回帖奖励
2587760959,如果您要查看本帖隐藏内容请回复
【温馨提示】技术问题 ...
发表于 2015-4-23 20:12:42 | 显示全部楼层
121212121212121
发表于 2015-4-23 20:18:15 | 显示全部楼层
学习一下啊
瞌睡得很
头像被屏蔽
2
主题
481
0
禁止发言
发表于 2015-4-23 20:43:04 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2015-4-23 23:49:39 | 显示全部楼层
{:soso_e183:}
等闲识得东风面,万紫 ...
发表于 2015-4-24 00:34:25 | 显示全部楼层
谢谢分享,学习一下
ok好 好
发表于 2015-4-24 13:13:25 | 显示全部楼层
thank you very much
