查看: 3016|回复: 1
[行业资讯] 关于挤出模具设计的一些中英文翻译!
发表于 2009-12-17 11:33:59 | 显示全部楼层 |阅读模式
1.Experienced with mechanical drawing and extrusion die design.
具备机械制图和挤出模具设计经验。
2.Secondly ,with the common materials of HDPE and PEEK, the variety conditions of temperature field and the pressure field of melt in the pipe runner are simulated , and the effect rules of velocity and quality of melt and the key geometry parameters of the die runner are confirmed under different geometry parameters and boundary conditions.
在此基础上修正调整了模具设计参数与流道不同的入口参数条件,确定了实验条件下合理的模具几何条件。 最后,依模拟条件设计加工了挤出模具并对HDPE进行了试验,由所得实验数据进一步分析了物料种类、流道成型段长度、机头温度对挤出产量、机头压力和挤出胀大的影响。
3.Through digesting and absorbing the technology of imported dies, and basing on our designing and production practice, the experience of designing and making of twin-screw extruder die for the extruding of special shaped profile was introduced in this paper.
本文通过对引进挤出模具的消化吸收,结合自己的设计、生产实践,介绍了挤出PVC异型材用双螺杆挤塑机机头模具的设计和制造经验。4.DESIGN OF THE DIE LIP-LENGTH FOR PLASTIC PLATE EXTRUSION
塑料板材挤出模具模唇长度设计
5.Through constructs based on the Internet technology comprehensive information platform,based on ERP system and based on the parallel project CAD/CAE/CAM system intellectualized local area network,analyzes CAD/CAE/CAM/ERP in to intrusion mold development,the design and the manufacture application.
通过构建基于Internet技术的综合信息平台、基于ERP和基于并行工程的CAD/CAE/CAM系统的智能化局域网络系统,分析CAD/CAE/CAM/ERP在挤出模具开发、设计及制造中的应用。
6.According to the current manufacturing situation of plastic profile extrusion die enterprises and the developing trend of CAPP system, a computer aided process planning system for the process design of plastic profile extrusion die was developed by using hybrid CAPP system, in which there are different decision-making functions of search, variant and generative.
本文根据塑料异型材挤出模具企业的生产现状和CAPP系统的发展趋势,采用综合式CAPP系统开发了塑料异型材挤出模具计算机辅助工艺设计系统。
7.This paper deals with the mould structure and empirical formulas for calculating die parameters, finalized design and pattern—rolling devices of PS fluorescent lamp-shade.
本文介绍PS日光灯罩挤出模具结构,口模参数经验计算公式,定型设计和轧花装置。
8.Study on Numerical Analysis of Plastic Extrusion Flow and Design Optimization of Extrusion Die
塑料挤出流动数值分析及其模具结构设计优化研究
9.The Design of Twin-Screw Extruder Die for Special-shaped Profile
挤出异型材用双螺杆挤塑机机头模具的设计
发表于 2010-5-13 22:28:40 | 显示全部楼层
谢谢分享.
