查看: 3546|回复: 1
[UG] 标准件 英文缩写
发表于 2015-10-24 11:44:57 来自手机 | 显示全部楼层 |阅读模式
有没有模胚中一些标准件对应的英文缩写表单
发表于 2015-10-25 08:38:50 | 显示全部楼层
三、模具
塑料模具mould of plastics
注塑模具injection mould
冲压模具die  模架mould base
定模座板Top clamping plate  Top plate   Fixed clamp plate
水口推板stripper plate  A板A plate  B板B plate
支承板 support plate
方铁 spacer plate
底针板 ejector plate
面针板 ejector retainer plate
回针 Return pin
导柱 Guide pin
有托导套 Shoulder Guide bush
直导套 Straight Guide bush
动模座板Bottom clamp plate  Moving clamp plate
基准线datum line
基准面datum plan
型芯固定板core-retainer plate
凸模固定板punch-retainer plate
顶针ejector pin
单腔模具single cavity mould
多腔模具multi-cavity mould
多浇口multi-gating
浇口gate
缺料starving
排气breathing
光泽gloss
合模力mould clamping force
锁模力mould locking force
挤出extrusion
开裂crack
循环时间cycle time
老化aging
螺杆screw
麻点pit
嵌件insert
活动镶件movable insert
浇注系统feed system
主流道 sprue
分流道runner
浇口gate
直浇口direct gate , sprue gate
轮辐浇口spoke gate , spider gate
点浇口pin-point gate
测浇口edge gate
潜伏浇口submarine gate , tunnel gate
料穴cold-slug well
浇口套sprue bush
流道板runner plate
排飞槽vent
分型线(面)parting line
定模stationary mould,Fixed mould
动模movable mould, movable half  上
模upper mould, upper half
下模lower mould, lower half
型腔cavity
凹模cavity plate,cavity block
拼块split
定位销dowel
定位销孔dowel hole
型芯core
斜销angle pin, finger cam
滑块slide
滑块导板slide guide strip
楔紧块heel block, wedge lock
拉料杆sprue puller
定位环locating ring
冷却通cooling channel
脱模斜度draft
滑动型芯slide core
螺纹型芯threaded core
热流道模具hot-runner mould
绝热流道模insulated runner mould
熔合纹weld line (flow line)
三板式模具three plate mould
脱模ejection
换模腔模具 interchangeable cavity mould
脱模剂release agent
注射能力shot capacity
注射速率injection rate
注射压力injection pressure
参与人数 1 +4 收起 理由
优胜网络服务 + 4 奖励 红包
