查看: 1468|回复: 0
[分享资料] VB进制转换源代码
发表于 2017-7-19 19:40:28 | 显示全部楼层 |阅读模式
VB进制转换源代码:
VB进制转换源代码
Function Bin2Dec(InputData As String) As Double
''  This converts Binary to Decimal
Dim DecOut As Double
Dim I As Integer
Dim LenBin As Double
Dim JOne As String
LenBin = Len(InputData)
''  Make sure that it is a Binary Number
For I = 1 To LenBin
JOne = Mid(InputData, I, 1)
   If JOne <> "0" And JOne <> "1" Then
     MsgBox "NOT A BINARY NUMBER", vbCritical
     Exit Function
   End If
Next I
DecOut = 0
For I = Len(InputData) To 1 Step -1
  If Mid(InputData, I, 1) = "1" Then
    DecOut = DecOut + 2 ^ (Len(InputData) - I)
  End If
Next I
  Bin2Dec = DecOut
End Function
Function Dec2Bin(InputData As Double) As String
''  Converts Decimal to Binary
''  This uses the Quotient Remainder method
Dim Quot As Double
Dim Remainder As Double
Dim BinOut As String
Dim I As Integer
Dim NewVal As Double
Dim TempString As String
Dim TempVal As Double
Dim BinTemp As String
Dim BinTemp1 As String
Dim PosDot As Integer
Dim Temp2 As String
''  Check to see if there is a decimal point or not
If InStr(1, CStr(InputData), ".") Then
  MsgBox "Only Whole Numbers can be converted", vbCritical
  GoTo eds
End If
BinOut = ""
NewVal = InputData
DoAgain:
''  Start the Calculations off
NewVal = (NewVal / 2)
''  If we have a remainder
If InStr(1, CStr(NewVal), ".") Then
  BinOut = BinOut + "1"
  '' Get rid of the Remainder
  NewVal = Format(NewVal, "#0")
  NewVal = (NewVal - 1)
   If NewVal < 1 Then
     GoTo DoneIt
   End If
Else
  BinOut = BinOut + "0"
   If NewVal < 1 Then
     GoTo DoneIt
   End If
End If
GoTo DoAgain
DoneIt:
BinTemp = ""
''  Reverse the Result
For I = Len(BinOut) To 1 Step -1
BinTemp1 = Mid(BinOut, I, 1)
BinTemp = BinTemp + BinTemp1
Next I
BinOut = BinTemp
'' Output the Result
Dec2Bin = BinOut
eds:
End Function
Function Bin2Hex(InputData As String) As String
''  Converts Binary to hex
Dim I As Integer
Dim LenBin As Integer
Dim JOne As String
Dim NumBlocks As Integer
Dim FullBin As String
Dim HexOut As String
Dim TempBinBlock As String
Dim TempHex As String
For I = 1 To LenBin
     Exit Function
   End If
Next I
''  Set the Variable to the Binary
FullBin = InputData
''  If the value is less than 4 in length, build it up.
If LenBin < 4 Then
If LenBin = 3 Then
  FullBin = "0" + FullBin
ElseIf LenBin = 2 Then
  FullBin = "00" + FullBin
ElseIf LenBin = 1 Then
  FullBin = "000" + FullBin
ElseIf LenBin = 0 Then
   MsgBox "Nothing Given..", vbCritical
   Exit Function
End If
  NumBlocks = 1
  GoTo DoBlocks
End If
If LenBin = 4 Then
  NumBlocks = 1
  GoTo DoBlocks
End If
If LenBin > 4 Then
Dim TempHold As Currency
Dim TempDiv As Currency
Dim AfterDot As Integer
Dim Pos As Integer
TempHold = Len(InputData)
TempDiv = (TempHold / 4)
''  Works by seeing whats after the deciomal place
Pos = InStr(1, CStr(TempDiv), ".")
If Pos = 0 Then
'' Divided by 4 perfectly
NumBlocks = TempDiv
GoTo DoBlocks
End If
AfterDot = Mid(CStr(TempDiv), (Pos + 1))
If AfterDot = 25 Then
  NumBlocks = (Len(FullBin) / 4)
ElseIf AfterDot = 5 Then
ElseIf AfterDot = 75 Then
Else
  MsgBox "Big Time Screw up happened, WAHHHHHHHHHHH", vbInformation
  Exit Function
End If
  GoTo DoBlocks
End If
''  The rest will process the now built up number
DoBlocks:
HexOut = ""
For I = 1 To Len(FullBin) Step 4
  TempBinBlock = Mid(FullBin, I, 4)
If TempBinBlock = "0000" Then
  HexOut = HexOut + "0"
ElseIf TempBinBlock = "0001" Then
  HexOut = HexOut + "1"
ElseIf TempBinBlock = "0010" Then
  HexOut = HexOut + "2"
ElseIf TempBinBlock = "0011" Then
  HexOut = HexOut + "3"
ElseIf TempBinBlock = "0100" Then
  HexOut = HexOut + "4"
ElseIf TempBinBlock = "0101" Then
  HexOut = HexOut + "5"
ElseIf TempBinBlock = "0110" Then
  HexOut = HexOut + "6"
ElseIf TempBinBlock = "0111" Then
  HexOut = HexOut + "7"
ElseIf TempBinBlock = "1000" Then
  HexOut = HexOut + "8"
ElseIf TempBinBlock = "1001" Then
  HexOut = HexOut + "9"
ElseIf TempBinBlock = "1010" Then
  HexOut = HexOut + "A"
ElseIf TempBinBlock = "1011" Then
  HexOut = HexOut + "B"
ElseIf TempBinBlock = "1100" Then
  HexOut = HexOut + "C"
ElseIf TempBinBlock = "1101" Then
  HexOut = HexOut + "D"
ElseIf TempBinBlock = "1110" Then
  HexOut = HexOut + "E"
ElseIf TempBinBlock = "1111" Then
  HexOut = HexOut + "F"
End If
Next I
Bin2Hex = HexOut
eds:
End Function
Function Hex2Bin(InputData As String) As String
''  PLEASE NOTE THAT THIS FUNCTION DOES
''            NOT
''  STRIP THE EXTRA ZEROS OFF THE FRONT OF THE
''  BINARY ANSWER.
''  Converts Hexadecimal to Binary
Dim I As Integer
Dim Lenhex As Integer
''  The length of the input
InputData = UCase(InputData)
Lenhex = Len(InputData)
For I = 1 To Lenhex
If IsNumeric(Mid(InputData, I, 1)) Then
  GoTo NumOk
ElseIf Mid(InputData, I, 1) = "A" Then
  GoTo NumOk
ElseIf Mid(InputData, I, 1) = "B" Then
  GoTo NumOk
ElseIf Mid(InputData, I, 1) = "C" Then
  GoTo NumOk
ElseIf Mid(InputData, I, 1) = "D" Then
  GoTo NumOk
ElseIf Mid(InputData, I, 1) = "E" Then
  GoTo NumOk
ElseIf Mid(InputData, I, 1) = "F" Then
  GoTo NumOk
Else
  MsgBox "Number given is not in Hex format", vbCritical
  Exit Function
End If
NumOk:
Next I
BinOut = ""
''  Convert the Number to Binary
For I = 1 To Lenhex
If Mid(InputData, I, 1) = "0" Then
  BinOut = BinOut + "0000"
ElseIf Mid(InputData, I, 1) = "1" Then
  BinOut = BinOut + "0001"
ElseIf Mid(InputData, I, 1) = "2" Then
  BinOut = BinOut + "0010"
ElseIf Mid(InputData, I, 1) = "3" Then
  BinOut = BinOut + "0011"
ElseIf Mid(InputData, I, 1) = "4" Then
  BinOut = BinOut + "0100"
ElseIf Mid(InputData, I, 1) = "5" Then
  BinOut = BinOut + "0101"
ElseIf Mid(InputData, I, 1) = "6" Then
  BinOut = BinOut + "0110"
ElseIf Mid(InputData, I, 1) = "7" Then
  BinOut = BinOut + "0111"
ElseIf Mid(InputData, I, 1) = "8" Then
  BinOut = BinOut + "1000"
ElseIf Mid(InputData, I, 1) = "9" Then
  BinOut = BinOut + "1001"
  BinOut = BinOut + "1010"
  BinOut = BinOut + "1011"
  BinOut = BinOut + "1100"
  BinOut = BinOut + "1101"
  BinOut = BinOut + "1110"
  BinOut = BinOut + "1111"
Else
  MsgBox "Something is Screwed up, Wahhhhhhhhhhh", vbCritical
End If
Next I
Hex2Bin = BinOut
eds:
End Function
Function Hex2Dec(InputData As String) As Double
''  Converts Hexadecimal to Decimal
Dim I As Integer
Dim HexStep As Double
'' Zeroise the output
DecOut = 0
''  Check to make sure its a valid Hex Number
For I = 1 To Lenhex
  GoTo NumOk
  GoTo NumOk
  GoTo NumOk
  GoTo NumOk
  GoTo NumOk
  GoTo NumOk
  GoTo NumOk
Else
  Exit Function
End If
NumOk:
Next I
HexStep = 0
''  Convert the Number to Decimal
For I = Lenhex To 1 Step -1
HexStep = HexStep * 16
If HexStep = 0 Then
  HexStep = 1
End If
   DecOut = DecOut + (0 * HexStep)
   DecOut = DecOut + (1 * HexStep)
   DecOut = DecOut + (2 * HexStep)
   DecOut = DecOut + (3 * HexStep)
   DecOut = DecOut + (4 * HexStep)
   DecOut = DecOut + (5 * HexStep)
   DecOut = DecOut + (6 * HexStep)
   DecOut = DecOut + (7 * HexStep)
   DecOut = DecOut + (8 * HexStep)
   DecOut = DecOut + (9 * HexStep)
   DecOut = DecOut + (10 * HexStep)
   DecOut = DecOut + (11 * HexStep)
   DecOut = DecOut + (12 * HexStep)
   DecOut = DecOut + (13 * HexStep)
   DecOut = DecOut + (14 * HexStep)
   DecOut = DecOut + (15 * HexStep)
Else
End If
Next I
Hex2Dec = DecOut
eds:
End Function
