Double elliptical spiral rotor parameters R macro variable milling technology research
摘要:双头椭圆螺旋转子螺旋曲面复杂、工作长度较大,在实际铣削加工中有较高难度。文章阐述了通过对双头椭圆螺旋转子截面特性分析及建立数学方程,并利用数控机床特性进行R参数宏变量编程铣削技术加工。
Abstract: Double elliptical spiral rotor screw surface complex, working length is bigger, has the high difficulty in the actual milling. Article elaborated through the double elliptical spiral rotor sectional characteristic analysis and mathematical equation, and use the features of the CNC machine tool R parameter the macro variables programming milling technology processing.
关键词: 椭圆螺旋 R参数 宏变量
Key words: The elliptical spiral R parameter macro variables
