查看: 1896|回复: 0
[分享资料] UGNX模块列表
发表于 2018-6-16 16:57:05 | 显示全部楼层 |阅读模式
UGNX模块列表
1. UG/入口(UG/Gateway)
2. UG/实体建模(UG/Solid Modeling)
3. UG/特征建模(Ug/Features Modeling)
4. UG/自由曲面建摸(UG/Freeform Modeling)
5. UG/用户自定义特征(UG/User-Defined Features)
6. UG/工程制图(UG/Drafting)
7. UG/装配建模(UG/Assembly Modeling)
8. UG/高级装配(UG/Advanced Assemblies)
9. UG/虚拟现实(UG/Reality)漫游(UG/Fly-Through)
10. UG/逼真着色(UG/Photo)
11. UG/标准件库系统(UG/FAST)
12. UG/WAVE技术
13. UG/几何公差(UG/Geometric Tolerancing)
CAM
1. UG/CAM基础(UG/CAM Base)
2. UG/后置处理(UG/Postprocessing)
3. UG/车加工(UG/Lathe)
4. UG/型芯和型腔铣削(UG/Core & Cavity Milling)
5. UG/固定轴铣削(UG/Fixed-Axis Milling)
6. UG/清根切削(UG/Flow Cut)
7. UG/可变轴铣削(UG/Variable-Axis Milling)
8. UG/顺序铣切削(UG/Sequential Milling)
9. UG/制造资源管理系统(UG/Genius)
10. UG/切削仿真(UG/VERICUT)
11. UG/线切割(UG/Wire EDM)
12. UG/图形刀轨编辑器(UG/Graphical Tool Path Editor)
13. UG/机床仿真(UG/Unisim)
14. UG/SHOPS
15. Nurbs(B样条)轨迹生成器(Nurbs(B-Spline) Path Generator)
CAE
1. UG/有限元分析(UG/Scenario for FEA)
2. UG/有限元(UG/FEA)
3. UG/机构学(UG/Mechanisms)
4. UG/注塑模分析(UG/MF Part Adviser)
钣金件(Sheet Metal)
1. UG/钣金件设计(UG/Sheet Metal Design)
2. UG/钣金制造(UG/Sheet Metal Fabrication)
3. UG/钣金件排样(Ug/Sheet Metal Nesing)
4. UG/高级钣金设计(Ug/Advanced Sheet Metal Design)
5. UG/钣金冲模工程(Ug/Sheet Metal Die Engineering)
用户化UG/Open
1. UG/Open Menuscript
2. UG/用户界面设计(UG/Open UIStyler)
3. UG/Open GRIP
4. UG/Open API
5. UG/Open++
WEB产品
1. UG/Web服务器(UG/Web Server)
2. UG/Web表示(UG/Web Express)
3. UG/Web渲染UG/(UG/Web Render)
基于知识的工程(Knowledge Based Engineering)
Ug/GenConnect
管路应用(Routing Applications)
UG/Routing, UG/Tubing, UG/Piping, UG/Conduit, UG/Raceway, UG/Steelwork.
UG/电气配线(UG/Harness)
质量工程应用(Quality Applications)
UG/设计检验, UG/检测,
UG/逆向工程(UG/Design Verification,
UG/Inspection, UG/Reverse Engineering)
数据交换(Data Exchange)
IGES,STEP,DXF二维交换和直接转换器
特殊应用(Special Applications)
UG/快速成型(UG/Rapid Prototyping)
UG/管理者(UG/Manager)
CADAM移植(CADAM Migration)
UG/移植(UG/MX)
