查看: 1084|回复: 0
[交流分享] 锌镁铝合金压铸件电镀喷涂工艺常用语
发表于 2018-10-30 15:21:41 | 显示全部楼层 |阅读模式
锌镁铝合金压铸件电镀喷涂工艺常用语:
1.电珍珠铬工艺常用语(Commonly used terminology in process for pearl chrome plating)
  硫酸清洗sulfuric acid clean
  超声波除蜡ultrasonic clean
  除油degreasing
  电解除油electro clean
  酸浸acid dip
  预镀碱铜alkali copper
  焦铜pyrophosphate copper
  酸铜acid copper
  半光叻semi-bright nickel
  氯化叻nickel chloride
  珍珠叻pearl nickel
  电铬chromium plated
  热水洗hot water rinsing
  烘干baking
  2.电光铬工艺常用语(Commonly used terminology in process for bright chrome plating)
  三氯乙烯清洗trichloroethylene clean
  上挂具racking
  除蜡水洗ultrasonic clean
  电解缸electro clean
  酸水acid dip
  预红铜电镀copper strike
  电红铜copper
  酸水acid
  酸铜acid copper
  氯化叻nickel chloride
  打底叻primer nickel
  镍色bright nickel
  电铬chromium plated
  烘干baking
  3.静电喷涂工艺常用语(Commonly used terminology in process for electrostatic coating)
  合格件上挂racking
  加热脱脂hot degreasing
  水洗rinsing
  酸洗acid dip
  中和neutralization
  表调surface conditioning
  磷化phosphating
  水洗二次rinsing x2
  烘干baking
  检查inspection
  上挂racking
  除尘dedusting
  喷涂spray painting
  固化curing
  下挂taking down
  包装packaging
  4.静电喷粉工艺常用语(Commonly used terminology in process for electrostatic powder)
  合格件上挂racking
  加热脱脂hot degreasing
  水洗rinsing
  中和neutralization
  钝化passivating
  水洗二次rinsing x2
  烘干baking
  检查inspection
  上挂racking
  除尘dedusting
  喷涂spray powder
  固化curing
  下挂taking down
  包装packaging
  补充词汇(Additional words)
  闪镀flash/falsh plate
  光亮电镀bright plating
  合金电镀alloy plating
  多层电镀multilayer plating
  金属喷镀metal spraying
  刷镀brush plating
  挂镀rack plating
  脉冲电镀pulse plating
  真空镀vacuum deposition
  热浸镀hot dipping
  离子镀ion plating
  滚镀barrel plating
  装饰性镀铬electroplating adom-chrome
  镀硬铬electroplating hard chrome
  钢铁发蓝/钢铁化学氧化blueing (chemical oxide)
  退镀stripping
  预镀strike
  化学抛光chemical polishing
  浸亮bright dipping
  活化activation
  机械抛光mechanical polishing
  粗化roughtening
  机械/化学粗化machine/chemistry coarsening
  敏化处理sensitization
