查看: 3060|回复: 3
[问题讨论] 求解
发表于 2011-10-3 14:07:30 | 显示全部楼层 |阅读模式
各位前辈:
请问powermill2011怎样制作右键菜单呢?谢谢!
发表于 2011-10-3 17:33:03 | 显示全部楼层
下载安装YSPM20100420-优胜PowerMILL编程外挂,点击进入
登录/注册后可看大图
计算本打开文件“C:\dcam\pmill2\user_menu”,右键菜单格式参考如下
U user_menu
T "优胜模具"
S
M "自动编程"
I "6把刀-1-D10R-D4R-R2-D4F-R1-D10F=S0" 1 "macro 'C:\dcam\pmill2\6把刀\铜公6把刀-1.mac'"
I "6把刀-5-D10R-D4R-R2-D4F-R1-D10F=S0" 1 "macro 'C:\dcam\pmill2\6把刀\铜公6把刀-5.mac'"
I "6把刀帮助" 5 "PMILLHELP URL 'C:\dcam\pmill2\6把刀\6把刀帮助.html'"
Z
S
M "加工模板"
I "1-T2-D10R平行开粗" 1 "macro 'C:\dcam\pmill2\加工模板\1-T2-D10R平行开粗.mac'"
I "1-T2-D8R平行开粗" 1 "macro 'C:\dcam\pmill2\加工模板\1-T2-D8R平行开粗.mac'"
I "2-T4-D4R二次开粗" 1 "macro 'C:\dcam\pmill2\加工模板\2-T4-D4R二次开粗.mac'"
I "2-T12-D3R二次开粗" 1 "macro 'C:\dcam\pmill2\加工模板\2-T12-D3R二次开粗.mac'"
I "3-T10-R1平行光刀曲面" 1 "macro 'C:\dcam\pmill2\加工模板\3-T10-R1平行光刀曲面.mac'"
I "3-T9-R2平行光刀曲面" 1 "macro 'C:\dcam\pmill2\加工模板\3-T9-R2平行光刀曲面.mac'"
I "3-T9-R3平行光刀曲面" 1 "macro 'C:\dcam\pmill2\加工模板\3-T9-R3平行光刀曲面.mac'"
I "4-T5-D4F等高光刀侧面" 1 "macro 'C:\dcam\pmill2\加工模板\4-T5-D4F等高光刀侧面.mac'"
I "4-T6-D3F等高光刀侧面" 1 "macro 'C:\dcam\pmill2\加工模板\4-T6-D3F等高光刀侧面.mac'"
I "5-T10-R1清角光刀" 1 "macro 'C:\dcam\pmill2\加工模板\5-T10-R1清角光刀.mac'"
I "5-T11-R0.5清角光刀" 1 "macro 'C:\dcam\pmill2\加工模板\5-T11-R0.5清角光刀.mac'"
I "6-T3-D10F平行光顶面" 1 "macro 'C:\dcam\pmill2\加工模板\6-T3-D10F平行光顶面.mac'"
I "7-T3-D10F光侧边" 1 "macro 'C:\dcam\pmill2\加工模板\7-T3-D10F光侧边.mac'"
I "8-T3-D10F平行光基准面" 1 "macro 'C:\dcam\pmill2\加工模板\8-T3-D10F平行光基准面.mac'"
I "9-T3-D10F光基准边" 1 "macro 'C:\dcam\pmill2\加工模板\9-T3-D10F光基准边.mac'"
Z
S
M "刀具路径"
M "木模加工"
I "木模刀具" 1 "IMPORT TEMPLATE PROJECT FILEOPEN'C:\dcam\pmill2\木模加工\木模刀具.ptf'"
I "左脚坐标" 1 "Macro 'C:\dcam\pmill2\木模加工\左脚坐标.mac'"
I "右脚坐标" 1 "Macro 'C:\dcam\pmill2\木模加工\右脚坐标.mac'"
I "小夹持工具打孔点" 1 "Macro 'C:\dcam\pmill2\木模加工\小夹持工具打孔点.mac'"
I "小夹持工具参考线" 1 "Macro 'C:\dcam\pmill2\木模加工\小夹持工具参考线.mac'"
I "大夹持工具打孔点" 1 "Macro 'C:\dcam\pmill2\木模加工\大夹持工具打孔点.mac'"
I "大夹持工具参考线" 1 "Macro 'C:\dcam\pmill2\木模加工\大夹持工具参考线.mac'"
Z
I "模型变换"     5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\wwl_move.exe'"
I "座标变换"     5 "ole fileaction 'open'  'C:\dcam\pmill2\VB程序\model_workplane.exe'"
I "铜公刀库"    1 "IMPORT TEMPLATE PROJECT FILEOPEN'C:\dcam\pmill2\刀具库\tool-H.ptf'"
I "钢料刀库"    1 "IMPORT TEMPLATE PROJECT FILEOPEN'C:\dcam\pmill2\刀具库\tool-L.ptf'"
I "建文件夹"  1 "macro 'C:\dcam\pmill2\宏程序\创建文件夹.mac'"
I "写字" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\PoweMILL_TextPattern.exe'"
I "轮廓加工"    1 "PMILLHELP URL 'C:\dcam\pmill2\VB程序\2D_Machining1.htm'"
I "刀路补正" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\Stork_Offset.exe'"
I "平行等高" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\平行+等高.exe'"
I "摆线加工" 1 "PMILLHELP URL 'C:\dcam\pmill2\VB程序\Trochoidal_MultiZ.htm'"
I "开放轮廓" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\wwl_2D.exe'"
I "钻孔攻牙" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\钻孔攻丝.exe'"
I "刀路重命名" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\PM Toolpath Rename.exe'"
I "刀路轴向平移0.3"      1 "EDIT TOOLPATH ; AXIAL_OFFSET 0.3"
I "刀具路径转参考线"    1 "CREATE PATTERN ;\r EDIT PATTERN ; INSERT TOOLPATH ;\r"
I "参考线转刀具路径"    1 "COMMIT PATTERN ; \r PROCESS TPLEADS"
I "边界线转刀具路径"    1 "commit boundary;\n"
I "快速沿面做参考线"    1 " edit pattern surface_raster "
I "五轴曲面法向加工"    1 "PMILLHELP URL 'C:\dcam\pmill2\VB程序\5Axis_RSM.htm'"
I "全部刀路过切检查" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\VerifyTP_ALL.exe'"
Z
S
M "路径编辑"
I "圆形圆弧" 1 "macro 'C:\dcam\pmill2\宏程序\圆形圆弧.mac'"
I "螺旋圆弧" 1 "macro 'C:\dcam\pmill2\宏程序\螺旋圆弧.mac'"
I "斜向下刀1.0" 1 "macro 'C:\dcam\pmill2\宏程序\NC100.mac'"
I "斜向下刀0.8" 1 "macro 'C:\dcam\pmill2\宏程序\NC85.mac'"
I "斜向下刀0.4" 1 "macro 'C:\dcam\pmill2\宏程序\NC40.mac'"
I "斜向下刀0.25" 1 "macro 'C:\dcam\pmill2\宏程序\NC25.mac'"
I "移到开始" 1 "EDIT TOOLPATH REORDER MOVE_START\r"
I "改变顺序" 1 "EDIT TOOLPATH REVERSE_ORDER" ""
I "顺逆铣反向" 1 "EDIT TOOLPATH REVERSE" ""
I "单双向切换" 1 "EDIT TOOLPATH ZIGZAG" ""
I "移动下刀点" 1 "QUIT LIMIT CANCEL CALCFORM CANCEL EDIT TOOLPATH MOVE_START_POINTS"
I "移动复制镜射" 1 "Macro 'C:\dcam\pmill2\宏程序\移动复制镜射.mac'"
I "刀具路径修剪" 1 "Macro 'C:\dcam\pmill2\宏程序\刀具路径修剪.mac'"
I "刀具路径分割" 1 "Macro 'C:\dcam\pmill2\宏程序\刀具路径分割.mac'"
Z
S
M "模型显示"
M "模型颜色"
I "白色" 1 "EDIT MODELSHADECOL WHITE"
I "红色" 1 "EDIT MODELSHADECOL RED"
I "绿色" 1 "EDIT MODELSHADECOL GREEN"
I "蓝色" 1 "EDIT MODELSHADECOL BLUE"
I "浅蓝" 1 "EDIT MODELSHADECOL CYAN"
I "浅紫" 1 "EDIT MODELSHADECOL MAGENTA"
I "黄色" 1 "EDIT MODELSHADECOL YELLOW"
I "橙色" 1 "EDIT MODELSHADECOL RED_YELLOW"
I "黄绿" 1 "EDIT MODELSHADECOL GREEN_YELLOW"
I "青绿" 1 "EDIT MODELSHADECOL GREEN_CYAN"
I "蓝青" 1 "EDIT MODELSHADECOL BLUE_CYAN"
I "紫色" 1 "EDIT MODELSHADECOL BLUE_MAGENTA"
I "粉红" 1 "EDIT MODELSHADECOL RED_MAGENTA"
I "深灰" 1 "EDIT MODELSHADECOL DARK_GREY"
I "浅灰" 1 "EDIT MODELSHADECOL LIGHT_GREY"
Z
I "显示平坦面" 1 "macro 'C:\dcam\pmill2\宏程序\DisplayFlats.mac'"
I "显示垂直面" 1 "macro 'C:\dcam\pmill2\宏程序\Displayverti.mac'"
I "显示倒扣面" 1 "macro 'C:\dcam\pmill2\宏程序\检查倒扣.mac'"
I "边界显示关" 1 "UNDRAW BOUNDARY ALL\r UNDRAW PATTERN ALL \r UNDRAW FEATURESET ALL\r"
I "曲面边线显示开" 1 "VIEW MODEL ; SHADE OUTLINES ON"
I "曲面边线显示关" 1 "VIEW MODEL ; SHADE OUTLINES OFF"
I "曲面内部阴影显示开" 1 "SET MODELSHADEDINSIDE"
I "曲面内部阴影显示关" 1 "UNSET MODELSHADEDINSIDE"
I "粗加工Z高度显示开" 1 "DRAW ZHEIGHTS"
I "粗加工Z高度显示关" 1 "UNDRAW ZHEIGHTS"
I "粗加工等高切面显示开" 1 "DRAW SLICES"
I "粗加工等高切面显示关" 1 "UNDRAW SLICES"
Z
S
M "后处理"
I "YS普通机设置" 1 "MACRO C:\dcam\pmill2\后处理\诺信数控.mac
I "YS高速机设置" 1 "MACRO C:\dcam\pmill2\后处理\法格自动换刀.mac
I "YS佳铁机设置" 1 "MACRO C:\dcam\pmill2\后处理\佳铁雕刻.mac
I "YS自动程序单" 1 "macro 'C:\dcam\pmill2\后处理\自动出单后处理.mac'"
Z
S
M "参数设置"
I "复原界面" 1 "Macro 'C:\dcam\pmill2\宏程序\界面复原.mac'"
I "最大界面" 1 "Macro 'C:\dcam\pmill2\宏程序\界面最大.mac'"
I "档案解锁" 1 "Project Claim"
I "英文界面" 1 "lang english"
I "中文界面" 1 "lang chinese"
I "系统初始化" 1 "Macro 'C:\dcam\pmill2\宏程序\reset.mac'"
I "刀路菜单回缩"   1 "EDIT PREFERENCE AUTOMINFINFORM YES"
I "帮助 HELP" 5 "PMILLHELP URL 'C:\dcam\pmill2\后处理\帮助.html'"
Z
发表于 2012-3-31 22:17:57 | 显示全部楼层
看不懂哦,有什么用的?还望高手指教。。
发表于 2012-7-14 19:54:56 | 显示全部楼层
user_menu
是怎么做出来的?
我装的powermill   10.0 在程序中找不到powermillutils怎么办?
