查看: 3049|回复: 5
[PowerMILL] 请问VB外挂怎么用?????
发表于 2011-11-27 00:53:36 | 显示全部楼层 |阅读模式
请问VB外挂怎么用?????
发表于 2011-11-27 01:17:18 | 显示全部楼层
应该是提高效率吧
发表于 2011-11-27 01:18:55 | 显示全部楼层
发表于 2011-11-27 08:39:37 | 显示全部楼层
一般的VB外挂都要注册相应的 PowerSolutionOLE.ocx 控件 才能使用 PowerSolutionOLE.ocx控件也有好几个版本 需要使用VB外挂的话最好下载完整版本的
发表于 2011-11-30 15:12:17 | 显示全部楼层
PowerMILL通常用VB程序语言做二次开发,VB开发的外挂添加到PM右键菜单上执行。
"user_menu"菜单文件格式如下:
Z
I "模型变换"     5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\wwl_move.exe'"
I "座标变换"     5 "ole fileaction 'open'  'C:\dcam\pmill2\VB程序\model_workplane.exe'"
I "铜公刀库"    1 "IMPORT TEMPLATE PROJECT FILEOPEN'C:\dcam\pmill2\刀具库\tool-H.ptf'"
I "钢料刀库"    1 "IMPORT TEMPLATE PROJECT FILEOPEN'C:\dcam\pmill2\刀具库\tool-L.ptf'"
I "建文件夹"  1 "macro 'C:\dcam\pmill2\宏程序\创建文件夹.mac'"
I "写字" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\PoweMILL_TextPattern.exe'"
I "轮廓加工"    1 "PMILLHELP URL 'C:\dcam\pmill2\VB程序\2D_Machining1.htm'"
I "刀路补正" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\Stork_Offset.exe'"
I "平行等高" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\平行+等高.exe'"
I "摆线加工" 1 "PMILLHELP URL 'C:\dcam\pmill2\VB程序\Trochoidal_MultiZ.htm'"
I "开放轮廓" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\wwl_2D.exe'"
I "钻孔攻牙" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\钻孔攻丝.exe'"
I "刀路重命名" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\PM Toolpath Rename.exe'"
I "刀路轴向平移0.3"      1 "EDIT TOOLPATH ; AXIAL_OFFSET 0.3"
I "刀具路径转参考线"    1 "CREATE PATTERN ;\r EDIT PATTERN ; INSERT TOOLPATH ;\r"
I "参考线转刀具路径"    1 "COMMIT PATTERN ; \r PROCESS TPLEADS"
I "边界线转刀具路径"    1 "commit boundary;\n"
I "快速沿面做参考线"    1 " edit pattern surface_raster "
I "五轴曲面法向加工"    1 "PMILLHELP URL 'C:\dcam\pmill2\VB程序\5Axis_RSM.htm'"
I "全部刀路过切检查" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\VerifyTP_ALL.exe'"
Z
S
