发表于 2011-12-10 16:46:34
显示全部楼层
这些是针对PM老版本用VB程序开发的外挂,对于PM10以后版本,基本上用不着了。
一般是加载到PM右键菜单上执行,user_menu格式如下:
I "模型变换" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\wwl_move.exe'"
I "座标变换" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\model_workplane.exe'"
I "铜公刀库" 1 "IMPORT TEMPLATE PROJECT FILEOPEN'C:\dcam\pmill2\刀具库\tool-H.ptf'"
I "钢料刀库" 1 "IMPORT TEMPLATE PROJECT FILEOPEN'C:\dcam\pmill2\刀具库\tool-L.ptf'"
I "建文件夹" 1 "macro 'C:\dcam\pmill2\宏程序\创建文件夹.mac'"
I "写字" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\PoweMILL_TextPattern.exe'"
I "轮廓加工" 1 "PMILLHELP URL 'C:\dcam\pmill2\VB程序\2D_Machining1.htm'"
I "刀路补正" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\Stork_Offset.exe'"
I "平行等高" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\平行+等高.exe'"
I "摆线加工" 1 "PMILLHELP URL 'C:\dcam\pmill2\VB程序\Trochoidal_MultiZ.htm'"
I "开放轮廓" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\wwl_2D.exe'"
I "钻孔攻牙" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\钻孔攻丝.exe'"
I "刀路重命名" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\PM Toolpath Rename.exe'"
I "刀路轴向平移0.3" 1 "EDIT TOOLPATH ; AXIAL_OFFSET 0.3"
I "刀具路径转参考线" 1 "CREATE PATTERN ;\r EDIT PATTERN ; INSERT TOOLPATH ;\r"
I "参考线转刀具路径" 1 "COMMIT PATTERN ; \r PROCESS TPLEADS"
I "边界线转刀具路径" 1 "commit boundary;\n"
I "快速沿面做参考线" 1 " edit pattern surface_raster "
I "五轴曲面法向加工" 1 "PMILLHELP URL 'C:\dcam\pmill2\VB程序\5Axis_RSM.htm'"
I "全部刀路过切检查" 5 "ole fileaction 'open' 'C:\dcam\pmill2\VB程序\VerifyTP_ALL.exe'" |
