帖子
查看: 18875|回复: 201
[转载文章] PowerMILL 2012 is now released
发表于 2012-3-9 20:06:44 | 显示全部楼层 |阅读模式
PowerMILL 2012 is now available to download from http://updates.delcam.com.
For a full list of all the new enhancements and improvements in PowerMILL 2012, please visit http://www.mailers.delcam.com/customers ... L2012.html
For a summary of the key new features in PowerMILL 2012 please visit http://www.delcam-ams.com/customers/PMI ... ts-new.asp
The maintenance date for PowerMILL 2012 is 2011.09, however, if your maintenance expires before that date please contact your local Delcam Sales Partner to arrange a demonstration or to discuss upgrading your maintenance.
New features and improvements in PowerMILL 2012 include:
• New Parametric Spiral toolpath strategy for improved undercut machining
• New Flowline Machining toolpath strategy for precise control and multiple surface machining
• Angular Point Separation for better surface finish and smoother machine motion
• New toolpath Z limits for machining deep parts in sections, including 5-axis operations
• New Spiral Blade Finishing option that minimises tool axis changes between passes to help you machine more parts
发表于 2013-11-12 10:39:38 | 显示全部楼层
好
发表于 2014-11-8 17:21:04 | 显示全部楼层
尽管我也知道一点,但是我还是要回些贴,工作太忙了,每天加班到12点,这么晚都过来了,难道回帖的精神都没有吗?
发表于 2013-10-10 11:40:09 | 显示全部楼层
发表于 2012-3-9 20:12:16 | 显示全部楼层
看看~是R2嗎?
 楼主| 发表于 2012-3-9 20:14:01 | 显示全部楼层
{:soso_e179:}去翻译吧
发表于 2012-3-9 20:30:38 | 显示全部楼层
学习学习
 楼主| 发表于 2012-3-9 20:31:42 | 显示全部楼层
{:soso_e192:}W  FAJIE 我发觉大家看都么看呢
发表于 2012-3-9 20:49:25 | 显示全部楼层
aaaaaaaaaaaaa
发表于 2012-3-9 22:25:37 | 显示全部楼层
发表于 2012-3-9 22:27:42 | 显示全部楼层
什么?哇哇哇哇... ...
发表于 2012-3-9 22:30:09 | 显示全部楼层
我帮大家翻译:
现在发布的2012中的2012个现在可以下载从http://updates.delcam.com。
一个完整列出所有新功能和改进的2012http://www.mailers.delcam.com/customers,请访问…l2012.html总结关键新功能的2012http://www.delcam-ams.com/customers/pmi请访问…ts-new.asp维护日期的2012是2011.09,然而,如果你的保修期满日期之前,请联系您当地的公司销售伙伴安排示范或讨论升级维护。新功能和改进的2012包括:
•新参数螺旋路径策略为改善切加工
•新流线加工轨迹战略的精确控制和多种表面加工
•角点分离较好的表面光洁度和平滑的运动
•新路径与限制加工深部分路段,包括五轴联动操作
•新螺旋叶片整理选项,减少刀具轴之间的变化将帮助你机器的零件
发表于 2012-3-10 21:47:52 | 显示全部楼层
微信小程序
微信订阅号
请微信扫码咨询
